Hot wheels v-drop finish gate spacing
I am going to make a start on a new track this week. I have plans in the future to adapt an old electronic finish gate from my slot car track which is hooked up to a laptop. But until then I am going to use a gate from a V-drop set, if I can find one.
Can anyone tell me the gap, if any, between the lanes can when connected to one of these gates?
Regards Keith
I did look at expert racer but I am in the UK and postage is quite expensive so I decided to go down the self build route.
Keith are you talking about the v-drop set that attaches to the top of a door and has an 'elevator/lift' system to load cars?
If yes, then the two lane track gate is side by side with no gap - which is roughly 1 and 5/8 inches (37mm) center line to center line.
Yes, thanks Milton that's the one.
I have got a Matchbox Superfast gate and that separates the lanes by 10 mm so I was expecting the Hot Wheels one to be similar. At least I can now can get on with the start gate and downhill section and hopefully find a Hot Wheels finish gate soon.
I'm using the v-drop finish line too and it's gap is practically not there, like Milton said. However, after time and thousands of races, a gap does form. Small and still negligible. The v-drop line has held up incredibly well for me...going on 5 years now and it still clicks like it should. But I think in the Spring when I can be outside with tools, I'm going to build a gate for the micro wizard I have, with the v-drop as the backup.
Although if I could find more v-drop sets, I would buy them simply for the finish gate.
just in case you might want to change to expert racers / drag tracks later... build to fit both... DT = 3.5" WIDE
